magside bearing
Posted: Fri Jan 08, 2010 5:47 pm
by mickdale
is a FAG NU2205E TVP2 (X-life 2707.k) stamped bearing the correct one for a gp magside?
cheers
mick
Re: magside bearing
Posted: Sun Jan 10, 2010 9:00 pm
by oldbiker
mickdale wrote:is a FAG NU2205E TVP2 (X-life 2707.k) stamped bearing the correct one for a gp magside?
cheers
mick
going through my old catalogues
nu2205 (correct size),
E (magneto bearing)
but wat the TVP is i`m not sure,
All the bearings with T** are very high load bearing suitable for haulage trollys.
I would guess that the 2 is the tollerance ,ie C1,C2,C3,etc
That`s the best I can do mate
Re: magside bearing
Posted: Sun Jan 10, 2010 9:02 pm
by mickdale
thanks
i think the TVP2 means its "standard" rating as opposed to C3 "high load"
cheers
mick
Re: magside bearing
Posted: Sun Jan 10, 2010 9:17 pm
by oldbiker
The numbers after the bearing size C1,C2,C3,etc are the radial clearence between the rollers and the tracks.
C1 is the standard,
C2 has a little more clearence,
C3 even more.
use C1 low clearence in shafts that run in a cold environment.
C3 and C4 are usualy used in hot environments such as on hot engines or electic motors.
The C rating has no relationship to the load bearing capacity of the bearing
that`s roughly what my fag catalogue says
