carb cable advice
Posted: Fri Jan 08, 2010 12:13 am
evening..
nearly finished with my rebuild, but having to tackle the little problems along the way.
could somebody point me in the right direction regarding what i need to set my keihin pwk carb up on my 186 mugello.
1., the throttle length of the cable seems short, where can i get the right size.( is it best to have a cable which has only one nipple for its respective carb on the end and free at the headset end.. and just use a adjustable locking nipple once fitted???????)
2., plus the choke is the same. i think i need one with a very small end on as the one i've got won't fit into the choke plunger assembly.
i can't remember but one of the lads on here does proper choke cable lengths
or i could be wrong..
3., whats best for giving the carb a good clean, carb degreaser? hot boiling water ? acid?
