Page 1 of 5
MB gear selector spring
Posted: Wed Jan 06, 2010 2:33 pm
by giankx
Hi, i've just started to build my Ts1 and i've fitted an MB selector spring.
Will i have problems changing the gears? Will it be too stiff?
Re: MB gear selector spring
Posted: Wed Jan 06, 2010 3:28 pm
by Ian Hepworth
You will have no problems if you use Nylon lined clutch and gear cables, routed with NO kinks or tight bends. Easy stuff!
Posted: Wed Jan 06, 2010 4:42 pm
by lifes a drag
i had an uprated spring with nylon lined cables all correctly routed ,, could i change gear ? not very easily
gave my mate ago to make sure it wasnt me being a whimp ,,, same with him ,,
Posted: Wed Jan 06, 2010 5:05 pm
by mark
same here
Posted: Wed Jan 06, 2010 5:17 pm
by DJB
I had one, but not from MB and i couldnt even get it into the layshaft. Standard ones are fine(I think) There's alot of crap about :
Posted: Wed Jan 06, 2010 9:58 pm
by giankx
Ok, but you refer all to the Mb spring or to other different ones?
I'll use nylon lined cables and hope to not have problems.
I Have bought these :
http://www.scooterrestorations.com/lamb ... ree-black/
Will they up the job?
Posted: Wed Jan 06, 2010 10:56 pm
by DJB
You could always call on popeye
Posted: Wed Jan 06, 2010 10:57 pm
by giankx
Posted: Wed Jan 06, 2010 11:00 pm
by cezeta
too stiff for me, ive never had a scooter jump out of gear either
Posted: Wed Jan 06, 2010 11:04 pm
by sean brady scooters
surely the stronger springs do what they are supposed to do and that is to help prevent gears jumping out ,and to provide a better /more positive selection.
although they may seem somewhat difficult at first,time and use will tame these....
