crank bearings
Tosh
just taken crank out to fit 110 yam rod into indian webs on the fly side the inner bearing track has india, nu2205e , nrb stamped onto it just wondering if this will be ok to leave on and still use the same bearing ,will still have to take plate off other side to see what bearing they have used then chage it if nes. am i better changing the seals as well as i can`t see what typ they are.
Thanks paul
as you have got this far with time and money a new set of bearings and seals is only gonna cost you £30 everytime i take a crank out i replace the drive side seal anyway ,the dribe side one is 6305 with c3 clearance and if poss get one with an extra seal in it ...i have a new SKF one at home if you want it for £5 as i cant see me using it for a good few years
