one piece clutch spider
Posted: Mon Jan 04, 2010 10:30 pm
by lammy250
which one do you pick, the mb one, or the foxhat
mb is pushing his for 5 real plates (3.5m)
what do i need to make my 5 plate into a 6???
im running a gp ts1
do i need a new pressure plate
what are the red and green clutch plates, the differences between the 2
do i need a new crown wheel???
Re: one piece clutch spider
Posted: Mon Jan 04, 2010 11:35 pm
by JOHNNY
if as al at foxhat says you use a foxhat spider and mb crown wheel you can go up to a 7 plate clutch no problems , ive a foxhat spider mb crown and am running a 6 plate on my ts
Posted: Tue Jan 05, 2010 10:34 am
by lammy250
but carnt i reuse my old crown wheel from the 5 plate that im using or do i just buy everything new??????
Posted: Tue Jan 05, 2010 1:53 pm
by RinB
If you've already got a 5 plate crownwheel you can use either spiders with 6 plates
Will need to change springs may be GT ones and change top pressure plate to 2-2.5mm.
Surflex 5 plate plates & corks will fit, just need additional one.
Posted: Tue Jan 05, 2010 6:11 pm
by lammy250
so whats the difference between the red and green plates?????????
is one a softer feel???
the reason im asking is because ive not been riding for the last couple of years and boy has things moved on!!!!!!!!!!!!!!!!!!!!!!!
Posted: Tue Jan 05, 2010 8:11 pm
by CPH Lambretta
LTH say the green ones are crap, they did some tests and a 5 plate clutch with green plates had less grip than a 4 plate clutch with Surflex B plates.
They rate the red ones though.
