Page 1 of 2
Kegra pipe for Vega
Posted: Sat Jan 02, 2010 8:28 pm
by Bobby Dazzler
I'm looking for one of these ( like Dave Thackwray has on his Vega).
I've heard that a couple of manufacturers are going to remake them and was wondering if anybody has any news on progress ?
Alternatively, is anybody who uses this site capable of making a copy for a reasonable price ?
Definite order for 2 if the price is right.
Re: Kegra pipe for Vega
Posted: Sun Jan 03, 2010 5:04 pm
by dirtyhandslopez
Bobby Dazzler wrote:I'm looking for one of these ( like Dave Thackwray has on his Vega).
Try Kegra, they may have a pattern. I know Graham has done a few. Might not be exactly the same.
Posted: Wed Jan 06, 2010 8:24 am
by Markus
Don't know if that helps, but Chiselspeed makes new expansion chambers (leg burners) for the Vegas.
Posted: Wed Jan 06, 2010 3:05 pm
by thackers
Last time i was talking to Mick Abbey he was thinking of making exhaust pipes. Sound him out you never know your luck. I heard a while back (probably read it on some forum somewhere) that Kegra won't consider making these pipes as the cost would be too much to make/sell. I could be wrong ?
Posted: Wed Jan 06, 2010 4:41 pm
by Mick Abbey
thackers wrote:Last time i was talking to Mick Abbey he was thinking of making exhaust pipes. Sound him out you never know your luck. I heard a while back (probably read it on some forum somewhere) that Kegra won't consider making these pipes as the cost would be too much to make/sell. I could be wrong ?
Hi I will be building pipes again if all goes to plan within the next 2 months I should be up and running, the only problem that I will have is that I would require the bikes to build them around as to ensure a perfect fit on the bike I will also be building one offs for custom machines
Mick
Posted: Wed Jan 06, 2010 4:53 pm
by RICSPEED
Mick Abbey wrote:thackers wrote:Last time i was talking to Mick Abbey he was thinking of making exhaust pipes. Sound him out you never know your luck. I heard a while back (probably read it on some forum somewhere) that Kegra won't consider making these pipes as the cost would be too much to make/sell. I could be wrong ?
Mick
i pm'ed him the number for baz that did grahams rgv pipes mick ,might be easier though as you could copy thackers pipe (if that was ok with him) as your both local to each other
Posted: Wed Jan 06, 2010 8:44 pm
by wack 63
Consider some sort of heat shield on the U bend and dont wear shorts in summer! Ouch
Posted: Wed Jan 06, 2010 8:51 pm
by sean brady scooters
even the std vega exhaust /silencer was fitted with heat shield grills....
and there are some very nice pipes made for twist and goes that could be quite easily adapted to fit and work on vegas,and could possibly work out a whole lot cheaper than making one from scratch.....
i.m in the process of building a 135 cc reed valve vega for a customer,and have here a pipe (leo vinci ) from a 125cc twist and go that only needs its overall tuned length adjusting /plus its reverse cone angle...but its got good volume and should work really well and will hopefully be cheaper in the the long run,compared to making a one off...
Posted: Wed Jan 06, 2010 9:23 pm
by thackers
Would that be for Cammi's Vega Sean? I was wondering how that was progressing. What did he use for the Reed valve? Did he go for the LTH option? Happy new year by the way
If Mick needs to use my pipe for a pattern i'm O.K with that
i'm still thinking of a Reed conversion myself maybe later in the year when i've got some more parts as at present i only have a barrel. Then i can have 2 top end kits to play with
Posted: Wed Jan 06, 2010 9:29 pm
by wack 63
Heres one I did earlier,went better than a Casa remade.Not that tidy but knocked up on a Sunday afternoon as an experiment
Oh and it's for sale/swap if anyone interested although a smoother curve U pipe would look better
