Modifying cowlings for AF flywheel..
Posted: Fri Jan 01, 2010 11:14 pm
First if your fitting a small flywheel modify the casing by removing the alloy that would normally be the edge to a standard flywheel As Paul Green has already shown... (The pick-up on the stator has white paint on it, which is in line with the laminates, this is to help align the magnets on the flywheel on assembly... incase any one noticed and wondered what was going on)
Then the head cowling needs to be give a cooling fin (Similar to the Italian GP) to help direct a little more air to the exhaust side. A cardboard template was made first, from this the fin cut from a sheet of steel, the edge folded in a vice and then clamped in place onto the head cowl.
The welding was done by drilling small holes in the cowling (but not through the cooling fin) these lined up with the fold of steel from the cooling fin, then welding the two together through these holes (plug welding), then a tack at either end with the mig to prvent it vibrating... (A spot welder would have been better)...
This fin helps cool the hottest part of the barrel a little more than on a standard SIL cowling. pic below...
In the pic above, I also add a second 8mm bolt hole to the head cowl, so that it can be bolted onto two long cylinder head nuts instead of just one as standard, giving four mounting points, which has to be better...
The last thing to do is to make sure the flywheel cowl is as tight a fit as possible to draw air in and push it into the head cowl where it cools the engine. The one in the picture has had the front face of the flywheel cowl cut off and then slid down till it touches a piece of card layed over the flywheel while all bolted to the engine and then tacked back in place then the small front piece which joins to the head cowl was cut out of a piece of sheet with snips and folded and beaten to shape then tacked, then the cowl was unbolted removed and welded with a mig, the fit is now so it sits about 1mm from the fins before it was about 20mm...pic below
The plug welds can be seen in the picture above that secure the fin into the head cowl an easy way to weld when no spot welder is available...
