Page 1 of 2
Heat Sinks for a cylinder head
Posted: Wed Dec 30, 2009 9:17 pm
by davidblythe
Thinking aloud so ready to be shot down in flames
did anyone see the new air cooled moto guzzi in MCN a few weeks ago that is using heat sinks connected to the cylinder heads acting as cooling radiators in the air flow
BY using all 4 cylinder head nuts extended and then all fastened to a non painted head cowling, would there be enough head conduction from the cylinderhead to the cowling which could be cooled by the passing air esp if you didnt run with the stand plate to make a difference
any thoughts
Re: Heat Sinks for a cylinder head
Posted: Wed Dec 30, 2009 9:42 pm
by sean brady scooters
its well worth trying dave as its quite easy to do...,i really dont know how much difference it would actually make but at least its a step in the right direction...i think that anything that helps cooling matters is well worth trying.
if used with many other mods to ensure max cooling it will make some difference.
Posted: Wed Dec 30, 2009 11:17 pm
by drunkmunkey6969
I like that Dave..........good idea!
Posted: Wed Dec 30, 2009 11:47 pm
just a guess....but is maybe dave suggesting extra long and wider cyl head nuts made from brass.... :D
if so ,then thats good. :D
Posted: Thu Dec 31, 2009 12:07 am
by davidblythe
sean brady scooters wrote:just a guess....but is maybe dave suggesting extra long and wider cyl head nuts made from brass.... :D
strangely i wasnt thinking that way :biggrin: but good idea
anyone remember the push in exhaust headers early brit bikes had with a heat sink star shaped collar on the header connected to the cylinder, will try that as well on a stub exhaust
Posted: Thu Dec 31, 2009 12:12 am
there is a very good reason as to why brass nuts were used on exhaust studs.....even though steel nuts would have been far cheaper to use.... ;)
Posted: Thu Dec 31, 2009 12:33 am
by davidblythe
just looked at the conduction tables, appreciated how good copper was but hadn't appreciated how good brass was over mild steel
Posted: Thu Dec 31, 2009 1:12 am
by davidblythe
just had a brainwave or am completely crackers
different to the above but should be a no brainer if i can get the material
Posted: Thu Dec 31, 2009 1:41 am
by J1MS
davidblythe wrote:just had a brainwave or am completely crackers
Alloy??
Posted: Thu Dec 31, 2009 8:05 am
by Special X
Lambretta fitted brass exhaust nuts to prevent them seizing onto the steel studs. This was the era of real engineering and most cars were fitted with brass exhaust manifold nuts as well. Removing a Mini exhaust manifold with seized nuts just doesn't bear thinking about :mrgreen:
