guinea pig ct1 piston
Posted: Wed Dec 30, 2009 11:17 am
66mm std bore.
compression hight 30mm.
skirt length 63mm.
16mm small end pin.
gona try this in a sr alu cylinder
this is what i have come up with given where the ports are in the cylinder to start with.
58mm stroke. 115mm yamaha 400 con rod.
2mm from top of cylinder giving 126.53 degs transfer.
45mm over port.
inlet 161.66 degs.
91mm to inlet floor.
skirt uncut. 63mm.
exhaust 186.74 degs. 31mm over port.
will be running a 28/30 scootrs pwk copy and an old micek.
any thoughts or comments from those in the know
would be much appreciated.
skirt length 63mm.
16mm small end pin.
45mm over port.
inlet 161.66 degs.
skirt uncut. 63mm.
