Page 1 of 2
IMOLA exhaust advices
Posted: Sun Dec 27, 2009 9:05 am
by ricky
hi all
i'm building an imola kit on my DL 125 and i will appreciate your advices
before buying the exhaust...
what the better ratio and gearing for this kit considering i want to keep a little bit of torque
and a large power band for a general use.
is the JL road franspeed a good solution ??
Please let me know
Re: IMOLA exhaust advices
Posted: Sun Dec 27, 2009 8:12 pm
by drew2
built my imola and fitted a JL4 seemed to pull like a train
and loved the revs,swapped to a devtour,pulled about
the same but didn't seem to rev out as much as the JL4,
swapped back to the JL4 now and loving it
Posted: Sun Dec 27, 2009 10:26 pm
by ricky
ok drew
but what kind of gearing do you use ?
what's the best ratio ??
Posted: Mon Dec 28, 2009 12:33 am
by corrado
Mine went great with Pacemaker box and 5.4 final drive, Mikuni TMX 27 & scootrs exhaust.
Posted: Mon Dec 28, 2009 8:47 am
by ricky
ok corrado
is it possible to know how you have jetted the carb ??
did you have the opportunity to try the JL Road exhaust ?
Posted: Mon Dec 28, 2009 11:36 am
by corrado
ricky wrote:ok corrado
Engine: Imola 186 kit.
Carb: THX 27 MM Mikuni, ran open mouthed.
Set up: Needle 5EL68-3
Pilot 20
Main 250
Power jet 60
Exhaust: ScootRS pipe.
I changed the gearing to 5.00 and fitted a Devtour thinking it would be better suited to motorway use just before I did Lands End to John O'Groats run but it totally ruined the performance and wouldn't pull 4th into headwinds and had to drop into 3rd for lots of inclines. Also the taller gearing doesn't increase the top speed as it can no longer rev as high. The Imola is tuned to rev so gear it accordingly.
Posted: Mon Dec 28, 2009 12:12 pm
by mark
i have just done an imola with a 30mm dellorto ,gp200 18/47 box , jl3 but i cant ride it
i am hoping it will pull me and wifey 2 up with trailer at a steady 55mph. will know in march i reckon
Posted: Mon Dec 28, 2009 5:33 pm
by CPH Lambretta
I'm doing an Imola at the moment:
Imola
JL4
30mm Dellorto Power jet
Li 150 box standard Sprockets (5.2)
What kind of clutch are you all useing or going to use?
I was thinking about a 5 plate MB clutch or can you get away with something cheaper?
Cheers Nick
Posted: Mon Dec 28, 2009 6:03 pm
by sjc
just building a engine for my mate imola 186 kit,, li 150 16 x 46 gearing,, 28mm dellorto,, scoot rs exhaust.. any idea on jetting details??
Posted: Mon Dec 28, 2009 7:00 pm
by ricky
CPH Lambretta wrote:What kind of clutch are you all useing or going to use?
Cheers Nick
i'm going to fit with a five plate clutch from tino but i do not know if the springs will be too strong to use ???
Concerning the gearing i've decided to keep the dl gear box 17/46 ( 5,4 )...
