Page 1 of 2
mag housing modification
Posted: Sun Dec 20, 2009 11:07 pm
by mnpes
:roll: looking @ the magside mod on the scootererotica racer...done for better cooling (air-flow)...ie grinding the alloy lip down.....is this a worthwhile modification on a fast road lambretta ? :)
Re: mag housing modification
Posted: Mon Dec 21, 2009 12:09 am
by paulmgreen
yes!
Posted: Mon Dec 21, 2009 3:38 pm
by GPMatt
well worth doing, but more so if you use a AF/ JB Plastitronic flywheel as they sit alot lower than the ~SIL fins IMO. ;)
Posted: Tue Dec 22, 2009 10:33 pm
by soulsurfer
Any mote details/pics of this mod? Is it not worth bothering with a SIL flywheel?
Is this a common thing on the track Paul?
Posted: Tue Dec 22, 2009 10:39 pm
by paulmgreen
Most scooters on the track are using a direct scoop for cooling, so there are no flywheel fans at all!
But Certainly anyone running a fan would modify to get as much air as possible circulating..... I'm stripping my race bike over christmas so will take some pics and publish.
Posted: Tue Dec 22, 2009 10:49 pm
by soulsurfer
Thanks Paul ;-)
Posted: Thu Dec 24, 2009 11:39 pm
by corrado
I did mine from roughly the 6 o'clock position to 9 o'clock position.
Posted: Fri Dec 25, 2009 12:55 pm
by cezeta
corrado, mine are removed completely. whats the pros and cons for part removal or complete removal?
Posted: Fri Dec 25, 2009 8:52 pm
by corrado
My tinpot thinking said that if you remove material before 6 o'clock it would help in flowing the air back out of the flywheel cowl and not forward into the cylinder cowl.
Posted: Fri Dec 25, 2009 9:53 pm
by cezeta
so i better just ride mine in the evening then ;)
