Ts 1 225 Carb
Posted: Fri Dec 18, 2009 9:11 pm
by roadrunnerian
Hi what carb should i put on my lammy ts 1 225 at the moment i am running an 34mm amal but every one says to use the mikuni any suggestions welcome thanks ian
Re: Ts 1 225 Carb
Posted: Fri Dec 18, 2009 9:17 pm
by DJB
If your Amal is set up i would leave it. If not a 35 tmx.
Re: Ts 1 225 Carb
Posted: Fri Dec 18, 2009 9:18 pm
by sean brady scooters
whats wrong with the amal ...?
Re: Ts 1 225 Carb
Posted: Sat Dec 19, 2009 4:19 pm
by roadrunnerian
nothing is wrong with my amal it has about 400 hundred miles only on it i have been told to put a different carb because the amal is hard to set and the mikuni 35 mm is a lot better and easy to set up and gives more miles to the gallon.
Re: Ts 1 225 Carb
Posted: Sat Dec 19, 2009 4:35 pm
by DJB
roadrunnerian wrote:nothing is wrong with my amal it has about 400 hundred miles only on it i have been told to put a different carb because the amal is hard to set and the mikuni 35 mm is a lot better and easy to set up and gives more miles to the gallon.
If you do change try these.
http://www.allensperformance.co.uk/prod ... bkits.html
Very good service and dont charge the earth like scooter dealers.
Re: Ts 1 225 Carb
Posted: Sat Dec 19, 2009 4:50 pm
by soulsurfer
There's a reason for that
Re: Ts 1 225 Carb
Posted: Sat Dec 19, 2009 7:09 pm
by Train Driver
I am using a 24mm mikuni on my 225 classic rapido and get about 55 mpg, i intend using the same carb on my RT260 kit, have discussed it with mark who said it will run fine
Re: Ts 1 225 Carb
Posted: Sat Dec 19, 2009 9:40 pm
by TS1-200
Mikuni`s are definitely a bit easier to set -up, but an Amal or Dellorto can be set up more accurately with a bit more effort. in my experience.
