Page 1 of 2
any demand for these in brass
Posted: Fri Dec 18, 2009 5:07 pm
by davidblythe
want to know if there is any demand out there
Managed to get a small length of 11mm hex bar in brass to make 6 sets over christmas
(you would have thought i wanted the holy grail getting it)
any interest out there
Re: any demand for these in brass
Posted: Fri Dec 18, 2009 5:29 pm
by dirtyhandslopez
Yes. Get Mark at Jet 200, he'll prolly want some. I'll take a pair.
Posted: Fri Dec 18, 2009 5:42 pm
by red
I'll have 2 sets please
Posted: Fri Dec 18, 2009 5:54 pm
by fred
i'll have a pair.
fred
Posted: Fri Dec 18, 2009 8:33 pm
by soulsurfer
I'll have a pair for a Clubman pipe ;)
Posted: Fri Dec 18, 2009 9:02 pm
by sean brady scooters
they are going like hot cakes dave.....you,d better get some more hex brass... :D
how much are they per pair....?
or are you now sold out.. :cry:
Posted: Fri Dec 18, 2009 9:26 pm
by davidblythe
Have enough hex bar for 6 sets, demand has surprised me esp combined with the lcgb site
will be ordering more brass but it is 10 times the steel cost, mainly because I can go direct to the main steel stockists and minimum order 6 Bars (ie 18 metres at a time)
Brass is a different matter, not really stocked in 11mm hexbar by even the large stock holders, they are not interested in ordering any in unless the order is seriously big time, but think I have found a major player in brass via a client which will bring price right down
price will be probably be a £1 more than the steel ones
an example for you a bar of 35mm round rod in brass is £157 plus Vat to account customers
Posted: Fri Dec 18, 2009 10:15 pm
by rog60
A set for me........................please. thanks
Posted: Sat Dec 19, 2009 5:19 pm
by dirtyhandslopez
This might sound stupid, but is 7/16's brass hex rod any cheaper because it's not "metric"? Still the same size wrench/spanner, what ever you want to call it. 'Nuther question-is it necessary to cut the stock back to round where it meets the manifold? Looks nice and everything but couldn't you save some machining time by leaving it hex shape throughout it's length? I don't think the washers used will mind :)
Where do we send money too?
Posted: Sat Dec 19, 2009 5:34 pm
by davidblythe
dirtyhandslopez wrote:This might sound stupid, but is 7/16's brass hex rod any cheaper because it's not "metric"? Still the same size wrench/spanner, what ever you want to call it. 'Nuther question-is it necessary to cut the stock back to round where it meets the manifold? Looks nice and everything but couldn't you save some machining time by leaving it hex shape throughout it's length? I don't think the washers used will mind :)
I do use 7/16's manufacturing tolerances of the hexbar normally measns they are a thou or so over 11mm,
measure most spanners and they are close to 11mm but always over by about 4 thou
11mm hex bar is virtually non existent even in steel
didnt use to do the final turned sections but some of the welded flanges intruded too far towards the holes, and the hex wouldnt tighten down fully esp when people didnt use spring washers
not taking any money until they are made
