Pitted Innocenti Rims
Posted: Thu Dec 17, 2009 7:22 pm
by TurboTrev
Have had a couple of original Innocenti rims blasted and primed. The outside of the rims are not too bad, but the insides have quite a bit of pitting. Is there any need to "cover" the pitting or can the tube happily sit against it? If people do "cover" it, what do you use? Cheers.
Re: Pitted Innocenti Rims
Posted: Thu Dec 17, 2009 7:26 pm
by soulsurfer
Personally, I'd have them blasted and powdercoated, this way the tend to be sealed and smooth.
Posted: Thu Dec 17, 2009 7:36 pm
by Daggs
A couple of coats of brush-on primer, and Bob's your auntie.
Posted: Fri Dec 18, 2009 11:37 am
by TurboTrev
^^^ Thanks for you replies. :)
Posted: Fri Dec 18, 2009 4:45 pm
by dirtyhandslopez
Where the rims are pitted, I would poke around with a point before coating, just make sure there isn't a real thin spot that could cause all sorts of dodgyness
Posted: Sat Dec 19, 2009 10:06 am
by red ghost
Daggs wrote:A couple of coats of brush-on primer, and Bob's your auntie.
Bob's a tranni ? :shock:
