Mag Housing
Posted: Wed Dec 16, 2009 11:55 am
by dapper
Rebuilding mag housing and having a bit of a problem seating the large circlip. Have faced it off a bit to try to sit it in the groove correctly. Is it common for the L shaped spacer to be able to spin/rattle once everything is put back together? Using Rolf outer seal, L shaped spacer, NU2205, Viton inner seal and large circlip.
Re: Mag Housing
Posted: Wed Dec 16, 2009 2:46 pm
by sean brady scooters
are you sure the bearing is seated in fully...?
Re: Mag Housing
Posted: Wed Dec 16, 2009 2:49 pm
by dapper
Reckon if I tap it any harder it'll come through the other side. All sorted now. Thank Christ at least you are awake Sean
