Page 1 of 2
can someone please explain dwell
Posted: Mon Dec 14, 2009 2:35 pm
by mark
was told to set a mates engine up with 30 degree dwell. what is it?
Re: can someone please explain dwell
Posted: Mon Dec 14, 2009 2:56 pm
by firekdp
It's the number of degrees that the points must remain closed to allow the flux to build up to a sufficient level in the HT coil in a battery powered ignition system.
Posted: Mon Dec 14, 2009 2:58 pm
by mark
so it dont matter in an electronic system
Posted: Mon Dec 14, 2009 3:05 pm
by firekdp
Correct, it doesn't matter.
Posted: Mon Dec 14, 2009 3:09 pm
by mark
thanks
Posted: Mon Dec 14, 2009 4:33 pm
by hungdog
Yeah it's quite easy really, wait for it.....................
Posted: Mon Dec 14, 2009 11:09 pm
by dsc scotty
Or are you talking dwell period? the amount of time/degrees the inlet port is clear of piston? as you stated 30 degrees I suspect that may be what you mean?
Posted: Mon Dec 14, 2009 11:16 pm
by sean brady scooters
this also crossed my mind when i saw this post,
dwell in terms of inlet timing is the amount of time that a port is fully open and unobstructed,
Posted: Tue Dec 15, 2009 12:36 am
by Daggs
I thought the 'dwell' is where the 'dwater' came from!
Sorry, i've been on the ale........... :bouncyeng:
Posted: Tue Dec 15, 2009 9:25 am
by mark
that sounds more like it sean thanks
