which piston
phil E
can somebody help, I am running a race rapido 225, 48mm clubman, 25mm dellorto with an LTH reed valve. Wanting to fit a more superior piston, ie, Wiseco or a jap piston or one of MB's pistons. I have also put this on LCGB forum so apologies if you have already seen it.
chris2470
Hi Phil
I too am looking for a lighter piston option as my 70mm is around 375g with the wrist pin.
The trouble is most will require a 18mm small end thus a con rod change, crank spit, and the true etc, which all costs. TBH the MB race-tour of your choice although a more expensive option than say a Suzuki Mitaka will still work out cheaper.
This is unless somebody knows of a Jap piston with 16mm small end, perhaps with an RD rod.
Suggestion would be appreciated.
Best Regards
Chris
davidblythe
go to 71mm and you could use the H2 piston
Honeymonster
f.y.o. I have a 69mm MB piston and it weighs 208g bare, used the wife's digital kitchen scales.
Ian
