TS1 250 ?
apc
anyone running a 250 like andy francis advertises? Just wondering if they are steel lined and the crankcase opened,etc.Pics and info appreciated,cheers Andy
soullad
Yep, I was curious too when I saw the ad.
Wondered if it was a true 250 or not. Probably a 62mm crank, with a standard 70mm piston??
dsc scotty
Done a couple! using 60mm stroked crank, liner etc, need some thought on inlet and exhaust timings though!
much depends on what pipe etc you are using etc.
what timings do you have...?and on what set up..?
    Users browsing this forum: Majestic-12 [Bot], Semrush [Bot] and 15 guests
