Page 1 of 2
rb 225 or 250 your Opinion
Posted: Mon Dec 07, 2009 8:30 am
by odd mod squad
hello all
whats the best the 225 or 250 pros and cons
i was thinking of building a rb 250 for my new project
all the best
Re: rb 225 or 250 your Opinion
Posted: Mon Dec 07, 2009 6:33 pm
by deany
not bored of your ferrari already Steve??
Posted: Mon Dec 07, 2009 9:15 pm
by tony
there's a write up in scootering this month on the 250.
Posted: Tue Dec 08, 2009 12:35 am
by corrado
Cons are that you need to have the crankcase mouth bored out to accept the spigot of the 250 thus rendering it useless to anything smaller than 250.
Posted: Tue Dec 08, 2009 12:54 am
by Train Driver
When i looked into a rapido 250 i was told apart from vibrating more (keep revs below 6500) they also run hotter, can anyone running one confirm this
Posted: Tue Dec 08, 2009 1:00 am
by tony
I would say that you are getting fairly close to the cylinder studs and so yes you may suffer from heat as at those points the cylinder wall is thin. They may of tried to compensate with more metal around the studs (i'm not sure) but whatever you do this has to be the 'weak area' of the large bore kits.
Posted: Tue Dec 08, 2009 1:16 am
by sean brady scooters
i dont really actually know exactly how relavant this is as yet but ,on all cast lambo barells the studs are exposed...to cool air.
this is so on all std vespas.
on most (if not all)ally kits for lambos they are inside,and so Not exposed to cool air.
while again on vespa kits wether cast or ally they are still exposed.
could this make a difference.....?
Posted: Tue Dec 08, 2009 1:19 am
by tony
so you are saying the orig cast iron barrels have exposed studs but the new designed ones they are enclosed.
Posted: Tue Dec 08, 2009 1:22 am
yes tony.
Posted: Tue Dec 08, 2009 1:24 am
by tony
i see.. interesting. malossi 172 t5 kit has exposed studs tho. But i'm reckoning it could be to do with more metal for anti seize.. or port angle maybe.
