Lambretta Inovations Hub Question
pedGY
Hi,
just finished the resto of my GP150 (with lots of help), passed it's MOT and now have it regiostered and a number plate on it, plan to get some miles on it over the weekend
My question is: Have fitted one of Frank's single anti dive hubs but the wheel is very stiff to turn and the stiffness seems to be coming from hub/spindle not the pads, did have a look at a sccot at the custom show at Brid that had the same set up and his wheel seemed to have the same 'problem' is this usual with these hubs and can i expect it to loosen up or have I done something wrong. Any advice or pointers most appreciated.
Ped
les perry
Main scooter: GP 230 TS1
why not email Frank,
It's not like that on mine, but Frank is your man.
pedGY
Cheers fellas,
i have emailed Frank, was hoping to be able to crack on with it tonight after a bit of advice, but will wait for Frank. was just impatient to get it out on the road after an 18 month project, a couple of more days won't hurt
regards
Ped
try loosening the spindle nut half a turn and see how it is then
darren112
one of the washers that sits next to the bearing .if it can touch the outer edge of the bearing .it will make the wheel bind :)
    Users browsing this forum: Ahrefs [Bot], Semrush [Bot] and 1 guest
