con rod replacement
Posted: Sat Dec 05, 2009 5:50 pm
by Tosh
going to have my top end tuned by sean after new year,i`m just wondering what kind of conrod to put into the indian webs would the mazzchelli con rod do , any idea`s
Re: con rod replacement
Posted: Sat Dec 05, 2009 6:56 pm
by eibargum
I had a 110 yam rod put in some indian webs at chiselspeed for another RB, i havent used it yet as ive changed my plans, thats the way i,d go if i were you, regards.
Posted: Sat Dec 05, 2009 8:34 pm
by gaz_powell
i use a 110 yam rod in indian webs on 2 of my ts1`s - only thing is you will need to use a pack plate - my other TS uses indian webs with a af race rod kit at 107 so no plate needed
i`ve just had a spare built with yam rod 110 and a 115 for another project
price wise it works out very reasonable as against buying af and other race cranks it should come in at about £65.00 + crank (which you already have) + packplate
Posted: Mon Dec 07, 2009 4:04 pm
by Tosh
thanks chaps for that was going with standerd length rod 107 unless sean tells me otherwise were would be the best place to purchase one from
Posted: Tue Dec 08, 2009 12:32 am
by corrado
I think Rayspeed use the Maz ones if they upgrade your Indian GP crank.
I'd go with the 110 Yam rod as it gives you more options with various packing plates to adjust the state of tune of the barrel.
