pwk carbs
Posted: Fri Dec 04, 2009 2:26 pm
by Tosh
what do you think of the carbs,was thinking of getting one before seeing sean after new year but i`ve read good/bad reports of people, looking at 30mm prob or a good second hand one of another type.
thanks paul
Re: pwk carbs
Posted: Fri Dec 04, 2009 2:58 pm
by shocky
Tosh wrote:what do you think of the carbs,was thinking of getting one before seeing sean after new year but i`ve read good/bad reports of people, looking at 30mm prob or a good second hand one of another type.
thanks paul
ive used them for about 4 yrs never had a problem they are very sebsetive to float heights though the last one was an OKO 30mm (same carb there all khelin copys) mine was the larger stub version so could be bored ot to 35mm i used radiator rubber for the manifold connector this gave me near 30mm of panel clearance on a TS1 at the lowest point check ebay out but make sure they have metal slides
Re: pwk carbs
Posted: Fri Dec 04, 2009 3:19 pm
by drunkmunkey6969
I think they are good value, if you are looking to save some money when purchasing a carb......but overall im not a fan.
I prefer the build quality and the adjustability of a Dellorto, and spares are easier to get hold of for Dellorto's too.
After Dellorto, i like Mikuni....again, better build quality than the OKO, spares readily available, not as adjustable in the mid-range as a Dellorto, but simple to set up and they flow well for performance gains at top end.
So apart from performance gains and build quality benefits, both Dellorto and Mikuni have an abundance of jetting info available from both suppliers and many scooter riders/forums etc to help you get set up, and the spares are readily available when you need them too.
For my dyno, i carry both Dellorto and Mikuni spares, but not OKO.
Re: pwk carbs
Posted: Fri Dec 04, 2009 3:32 pm
by shocky
theres plenty of suppliers of spares SUDCO or allens performance are the 2 i used, also dont just limit yourself to scooter dealers plenty of off road bikes use these carbs or there variants ... but like dan says theres plenty of info on other carbs and getting the jetting pretty close to start with is gonna be alot eisier from the off i have found the jets and neddles to be about half the price of dellorto ones and bought a case of 20 jets for £18 last year and 5 neddles for about the same from my local motocross shop
Re: pwk carbs
Posted: Fri Dec 04, 2009 3:40 pm
by Tosh
thanks gents for that think i`ll bang mi head against a wall and have a re-think
Re: pwk carbs
Posted: Sat Dec 05, 2009 1:28 am
by coaster
I've been running an oko PWK 28/30 (scootRs) on my Mugello 186 for a few years and it is fine. Like Shocky said, you can get the needles and jets from a few places including scootRs. I tend to get them on line from a German dealer. Since I got the jetting dialed in it has been absolutely fine. It's very light and is still on the original mounting rubber it was supplied with. I will most likely buy another one for the 225 I'm putting together.
Re: pwk carbs
Posted: Sat Dec 05, 2009 11:35 am
by ArmandTanzarian
coaster wrote:I've been running an oko PWK 28/30 (scootRs) on my Mugello 186 for a few years and it is fine. Like Shocky said, you can get the needles and jets from a few places including scootRs. I tend to get them on line from a German dealer. Since I got the jetting dialed in it has been absolutely fine. It's very light and is still on the original mounting rubber it was supplied with. I will most likely buy another one for the 225 I'm putting together.
Both of mine (24 and 28) had serious fuel starvatiuon issues and the 24 had a choke spring so weak that it never really ran right.
Re: pwk carbs
Posted: Sat Dec 05, 2009 5:59 pm
by Lor@n
I'm running a PWK 28/30 (scootRS) on my Imola S2 for years without problems.
And it was even easier to jet than the Dellorto PHBH30.
And also running a PWK 24 (scootRS) on an indian GP200.
For what it costs, buy all the jets and needles with your carb.
Re: pwk carbs
Posted: Sat Dec 05, 2009 6:45 pm
by coaster
I believe there was an issue with some early PWK copies which needed the fuel inlet drilling out but that was a few years ago, I bought mine in 2004 from ScootRs and apart from my inept attempts at jetting (I lack the patient methodilcal approach :oops: ) it has been fine. I bought a choke upgrade from a German site but ended up putting the ScootRs one back in.
