Questions about gear selector spring and clutch bush.
Posted: Sun Nov 29, 2009 4:57 pm
by ArKaTxU
Hi.
What do you think about to put in a road engine (RB20) an uprated gear selector spring (little less hard than the Taffspeed ones)? (all the engine is still in box)
I have a clutch bush and when i want to put in the clutch sprocket is very hard. I think that if i use something to put in i can put, but there is no play and the bush cant move into the sprocket. Is this bush right or is not important the bush movement into the sprocket?
Thanks for your help!
Arkaitz
Re: Questions about gear selector spring and clutch bush.
Posted: Mon Nov 30, 2009 9:29 pm
by ArKaTxU
Someone?
Posted: Tue Dec 01, 2009 12:43 pm
by leigh
Not sure about the clutch bush but i have a standard spring in my gear selector on an rb22 been running for a couple of years now with no problems
Leigh
Posted: Tue Dec 01, 2009 4:26 pm
by dapper
[quote="ArKaTxU"]Hi.
Can you explain a bit better? Getting a bit lost in translation :|
Posted: Tue Dec 01, 2009 9:50 pm
by ArKaTxU
dapper wrote:
ArKaTxU wrote:Hi.
Ok sorry.
I have an uprated gear selector spring and i am asking if is this ok to put in a RB20 engine or is very hard.
And i have a bronze clutch bush, and when i put in the clutch sprocket i cant move into it. Is this ok?
Thanks!
Posted: Tue Dec 01, 2009 11:16 pm
by Supereibar
Arkatxín, necesitas ayuda chaval? Ni yo mismo entiendo lo que estás diciendo JA JA JA JA!!
By the way dude, are you trying to put a broze bush or cymbal? whats the story there?
Posted: Tue Dec 01, 2009 11:23 pm
by ArKaTxU
Supereibar wrote:Arkatxín, necesitas ayuda chaval? Ni yo mismo entiendo lo que estás diciendo JA JA JA JA!!
This is for Supereibar:
Joderrrrrr, a ver traduceme please:
Tengo un casquillo de bronce del que se pone en la corona de embrague, pero resulta que entra muy duro, lo puedo meter golpeando con algo, pero quedaria encajado, luego al meter la araña esta si gira bien, pero no se si es un problema que este casquillo de bronce quede encajado en la corona.
Esa es una, otra es que tengo un muelle del selector del cambio reforzado (algo mas duro que el de Taffspeed) y queria saber si es necesario usarlo o con el de serie va que chuta con el RB20.
Gracias tio!
