scoot rs slave rubbing on scoot rs rim?
Posted: Sun Nov 29, 2009 3:11 pm
by cezeta
i have a scoot rs disc fitted with a scoot rs rim and the slave cylinder rubs on the rim only by a tadd.
anyone else had this....is it ok just the file the slave to give a bit of clearance or am i missing something?
Re: scoot rs slave rubbing on scoot rs rim?
Posted: Sun Nov 29, 2009 3:37 pm
by odd mod squad
last month my mate had the same problem,he filed down the calliper and then added washers behind the hub studs to space it
not recommended
i think the early rimms had this problem but i thought rs had sorted it
Posted: Sun Nov 29, 2009 4:19 pm
by soulsurfer
Yep, normal.
If you search through the mire of the ScootRS website, it says so, you just have to find it
TBH it pissed me off when I found out
Posted: Sun Nov 29, 2009 5:33 pm
by ArmandTanzarian
They all do that sir. You only have to shave a tiny bit off the caliper. A half hour job. I think it does warn you on the ScootRS site but it isn't exactly obvious
Posted: Sun Nov 29, 2009 9:35 pm
by drew2
yes,a bit of dremmelling on the caliper and a bit
of fettling and bob's your uncle
