Page 1 of 2
Scooter Loopy John exhaust clamp - too small?
Posted: Sun Nov 29, 2009 1:03 pm
by dansuper
Just bought a KBA 42mm clubman and SLJ 'seal tight' exhaust clamp.
The clamp fits over the U bend with a couple of mm to spare, but has to be massively stretched to fit over the outlet of the box. It can't be right as the bolts do not even make through all the way when fitted.
The KBA slotted 'neck' is about 47mm, which fits around the U bend with a couple of mm to spare each side - which I presume is correct.
Anybody else have this issue? I guess the clamp would be too big for a standard pipe, so if it doesn't fit the 42mm KBA, what is it for?
I've asked the supplier to investigate for me, too.
Hmmmm - having just written all of the above, I now have a bad feeling that the pipe may actually be a 48mm - as I had to bend the slots in a little to fit more tightly around the U bend. But the clamp still seems too small. I dunno.
Cheers,
Dan
Re: Scooter Loopy John exhaust clamp - too small?
Posted: Sun Nov 29, 2009 1:39 pm
by goldeneye
so what your saying is, you"ve got the wrong pipe on the wrong u-bend, and its all john churchills fault for selling you an exhaust clamp?
Posted: Sun Nov 29, 2009 1:50 pm
by corrado
goldeneye wrote:so what your saying is, you"ve got the wrong pipe on the wrong u-bend, and its all john churchills fault for selling you an exhaust clamp?
It's always the dealer's fault isn't it?
Posted: Sun Nov 29, 2009 1:54 pm
by firekdp
Why would he blame the bloke that makes the fibreglass panels?
Or do you mean John Madison?
Posted: Sun Nov 29, 2009 2:03 pm
by goldeneye
if he can get his exhaust bits mixed up, i"m allowed to get me johns mixed up alright!
Posted: Sun Nov 29, 2009 2:26 pm
by firekdp
Posted: Sun Nov 29, 2009 9:31 pm
by dansuper
LOL - thanks for the 'help'...
By supplier, I meant 'dealer'. Not manufacturer. I purchased all three items from the same dealer so am just trying to work out which one is 'wrong'.
Not really sure how tight the U bend is meant to be into the pipe, but I'm going to measure everything up again as it may well be a 48mm pipe supplied with a 42mm u bend.
Posted: Sun Nov 29, 2009 9:43 pm
by byron
dansuper wrote:Not really sure how tight the U bend is meant to be into the pipe, but I'm going to measure everything up again as it may well be a 48mm pipe supplied with a 42mm u bend.
you'd know if the box & header were mismatched in that way, be like tom thumb inside annabel chong.
the u-bend should push in fairly easily, but not so it would fall straight out if you held it upside down
Posted: Sun Nov 29, 2009 11:14 pm
by eibargum
I too have one of these exhaust clamps, its been on two other 42mm ish exhaust,s and it fitted fine ,in fact its the best ive ever used
, but it wont fit on my 42mm KBA clubman
, thier good clamps, it seems the KBA must be slighty on the large size for a 42mm jobby.
Posted: Mon Nov 30, 2009 12:30 am
by ScooterLoopyJohn
Hi just lately a/f have made there 42mm exhausts out of thicker material this has caused me to make 42 clamps 1 mm bigger on dia. as kba 42mm clubmans are from the same sourse it only follows that they now need the new clamps. my clamps only cover about 1 mm dia change as they are job spacific. return any non fitting clamps and i will mod or replace with suitable replacement ones Merry Xmas John
