Page 1 of 7
LTH Reed
Posted: Sat Nov 28, 2009 9:32 am
by Dazza
I'm seriously thinking about getting one of these, mate it up to my knackered (soon to be re-sleeved) rapido 225,new piston and Mikuni TM30.
Fisrstly opinions elsewhere seem good - anyone on here tried one yet?
Anyone know where to get one? LTH seem to be sold out?
I've also seen people saying that the piston needs work to get the most out of it , does it?
If the piston does need work I would like to think the chap whos going to do the re-sleeve (Fahron engineering) will be able to do the work - should a decent 2-stroke tuner know where to run with this?
I really fancy doing this but I have One BIG thing at the back off my mind - by the time ive bought a new piston,paid for a re-sleeve, manifold would I have been better just getting a TS1?
So many questions...
Re: LTH Reed
Posted: Sat Nov 28, 2009 1:33 pm
by sean brady scooters
I,ve just done one
LTH reedblock onto Rapido 225,modified the piston and cut new boost port into barrel.
its all still on the bench so I,ll get some piccys posted if that helps.
Re: LTH Reed
Posted: Sat Nov 28, 2009 1:42 pm
by teamsequipe
Hi Dazza
I've recently been having some work done by Broady, and we've tried an LTH Reed manifold. A significant amount of work was required to get the correct reed to sit in, and then some more work to dowel the manifold to the barrel so to avoid any movement as the manifold is made to fit both 150 and 200 variants.
Anyhow, here's a graph of before and after:
The solid lines show the results after fitting the reed, 27bhp and 20lb torque......... nice ! :D
and a couple of shots of the modded manifold:
I have stacks more graphs, which I'm gonna sort out and post in the correct area later this weekend.
Cheers
Darrell
Re: LTH Reed
Posted: Sat Nov 28, 2009 2:00 pm
by CT.
That's excellent, I like the nice increase in torque at low rpm's as well as the overall improvement.
By the side of the graph is says RT255, is this a typo or is the CC 255 ? When you say 'correct read' , which ones are you using ?
Ta.
Re: LTH Reed
Posted: Sat Nov 28, 2009 2:08 pm
by Dazza
sean brady scooters wrote:I,ve just done one
Which piston did you use Sean? - I think I may have just found someone to carry out the work if I go ahead ;)
Darrell, have you ridden it yet ? just wondering if it makes as much difference to the rideability as they claim?
Re: LTH Reed
Posted: Sat Nov 28, 2009 2:11 pm
it was done with the rapido piston
Re: LTH Reed
Posted: Sat Nov 28, 2009 2:12 pm
by Dazza
CT. wrote:By the side of the graph is says RT255, is this a typo or is the CC 255 ? When you say 'correct read' , which ones are you using ? Ta.
I think it is an RT CT
I think Darrells comments are based on the LTH reed
Re: LTH Reed
Posted: Sat Nov 28, 2009 3:41 pm
by J1MS
Sean when you cut the boost ports into the Rapido did you port through the steel liner into the surrounding alloy, or just into the liner, I wanted to cut mine deeper but was unsure if the integrity of the alloy was up to sealing if I cut too deeply into it...
What are do you think Sean.
Re: LTH Reed
Posted: Sat Nov 28, 2009 4:05 pm
On this one i have only cut one central boost, which is angled up to intake manifold area
which is mostly dont forget,all steel.
so it has not gone through to alloy..
even if you cut 3 boosts i still doubt you would go into the alloy anywhere :D
Re: LTH Reed
Posted: Sat Nov 28, 2009 4:07 pm
by CT.
Thanks, I understand that its an MB Racetour but was referring to the cylinder capacity.
