Heat Sinks for a cylinder head
davidblythe
Thinking aloud so ready to be shot down in flames
did anyone see the new air cooled moto guzzi in MCN a few weeks ago that is using heat sinks connected to the cylinder heads acting as cooling radiators in the air flow
BY using all 4 cylinder head nuts extended and then all fastened to a non painted head cowling, would there be enough head conduction from the cylinderhead to the cowling which could be cooled by the passing air esp if you didnt run with the stand plate to make a difference
any thoughts
its well worth trying dave as its quite easy to do...,i really dont know how much difference it would actually make but at least its a step in the right direction...i think that anything that helps cooling matters is well worth trying.
if used with many other mods to ensure max cooling it will make some difference.
I like that Dave..........good idea!
just a guess....but is maybe dave suggesting extra long and wider cyl head nuts made from brass.... :D
if so ,then thats good. :D
davidblythe
sean brady scooters wrote:just a guess....but is maybe dave suggesting extra long and wider cyl head nuts made from brass.... :D
strangely i wasnt thinking that way :biggrin: but good idea
anyone remember the push in exhaust headers early brit bikes had with a heat sink star shaped collar on the header connected to the cylinder, will try that as well on a stub exhaust
there is a very good reason as to why brass nuts were used on exhaust studs.....even though steel nuts would have been far cheaper to use.... ;)
davidblythe
just looked at the conduction tables, appreciated how good copper was but hadn't appreciated how good brass was over mild steel
davidblythe
just had a brainwave or am completely crackers
different to the above but should be a no brainer if i can get the material
J1MS
davidblythe wrote:just had a brainwave or am completely crackers
Alloy??
Special X
Lambretta fitted brass exhaust nuts to prevent them seizing onto the steel studs. This was the era of real engineering and most cars were fitted with brass exhaust manifold nuts as well. Removing a Mini exhaust manifold with seized nuts just doesn't bear thinking about :mrgreen:
    Users browsing this forum: Amazon [Bot], Google [Bot] and 7 guests
