Page 1 of 2
GP engine Cutting Out
Posted: Fri Nov 27, 2009 2:52 pm
by Spud
When i am in 4th gear & go full throttle (not sure whether it happens after 1/2 or 3/4 throttle), my engine bogs down & cuts out, as if i had run out of fuel.
When acccelerating through the gears, I didn't notice it.
I have plenty of petrol & i am using a fast flow tap.
If i pull over, the engine recovers.
Any ideas?
cheers
Spud :?
Re: GP engine Cutting Out
Posted: Fri Nov 27, 2009 3:15 pm
by corrado
1st port of call for me would be removing the carb and giving it a thorough clean and probably flushing the tank through a couple of times with clean fuel.
May not solve anything but costs nothing and can't do any harm.
Posted: Fri Nov 27, 2009 4:04 pm
by Daggs
Check the tank cap breather is completely clear.
Are you sure it's a fast flow tap?
Inspect the fuel flow needle in the carb and the float movement.
Posted: Fri Nov 27, 2009 4:15 pm
by joee
dont drive so fast
here to help
Posted: Fri Nov 27, 2009 4:51 pm
by Spud
Already had the carb apart & cleaned it out.
Can't see any problems with the movement of the float
It is defo a fast flow tap.
will check the petrol cap breather though!
Posted: Fri Nov 27, 2009 7:01 pm
by dapper
Could it be your carb hose collapsing with the sudden vacuum?
Posted: Fri Nov 27, 2009 8:26 pm
by chris2470
Have you got a ScootRs PWK buy any chance ?
One with a clear float bowl.
Posted: Fri Nov 27, 2009 8:52 pm
by Dazza
I know you say you've got a fast flow fuel tap - but have you measured it's flow?
I had exactly the same symptoms - only in 4th, I tried numerous 'fast flow ' taps but only got enough flow with one from camlam.
Or have you tried the breather hole in the cap?
Posted: Fri Nov 27, 2009 9:18 pm
by Spud
Yes Chris i do have a ScootRs PWK.
It is the one with a clear float bowl.
Posted: Fri Nov 27, 2009 9:31 pm
by ForemanBob
Spud wrote:Yes Chris i do have a ScootRs PWK.
In that case you probably have the common case of the float bowl running dry :flaming:
To verify this for yourself.... when it happens reach down and switch off the fuel tap and check the float bowl. It will be empty :shock:
You will join many of the other victims of this carb, however once you take the short time to fix it, the carb is extremely rewarding.....
http://www.forums.ilambretta.com/viewto ... 15&t=17598
You will see a raised lug at the bottom of the float bowl, burn this off with a soldering iron, and check for the free operation of the float, that it's not fowling on anything else (mine was on the 45deg brass overflow pipe, and I fettled the plastics to free it off)
I also did the other mods to the inlet holes in the float valve chamber, and opening up the small hole near to the main jet; just for luck when I was at it. :mrgreen:
let us know how you get on.
Bob
