sx headstock
Posted: Wed Nov 25, 2009 10:40 pm
by stuart rimmer
can anyone tell me the diameter of the steel bar that is fitted in to both sides of the headstock for throttle and gearhousing to fit onto as my gear side has snapped and needs a peice welding thanks
Re: sx headstock
Posted: Wed Nov 25, 2009 11:06 pm
by rog60
stuart rimmer wrote:can anyone tell me the diameter of the steel bar that is fitted in to both sides of the headstock for throttle and gearhousing to fit onto as my gear side has snapped and needs a peice welding thanks
Do you mean the steel tubing that projects from the ends of the handlebars :?: :?: :?:
Re: sx headstock
Posted: Wed Nov 25, 2009 11:17 pm
by stuart rimmer
yes mate the steel that is fitted into headstock looks like handlebars when you take everything off the headstock
Re: sx headstock
Posted: Wed Nov 25, 2009 11:52 pm
by RICSPEED
22mm
Re: sx headstock
Posted: Thu Nov 26, 2009 12:13 am
by stuart rimmer
thanks mate , now where to get some 22mm tube from anyone
Re: sx headstock
Posted: Thu Nov 26, 2009 12:20 am
by RICSPEED
most enginering workshops would be happy to sell you some
Re: sx headstock
Posted: Thu Nov 26, 2009 12:26 am
by rog60
RICSPEED wrote:most enginering workshops would be happy to sell you some
And splice a piece on the end to replace the damaged bit. Had that done on a S3 gear support that had rusted badly at the end.
