Bearing experts
Posted: Tue Nov 24, 2009 3:57 pm
by corrado
Re: Bearing experts
Posted: Tue Nov 24, 2009 5:08 pm
by dapper
Martin, think this refers to how tight the bearing play is (look at second chart)
http://www.smallparts.com.au/technical/ ... clearance/
This explains it a bit better.
In ball bearings, as the radial clearance increases, the axial clearance increases as well. The more room between the balls and the rings (radial clearance), the more the elements can shift in relation to each other. Generally, internal clearances are designated from C1 (the tightest) through to C5 (the loosest or largest). The 'normal' clearance is CN, a range sitting between C2 and C3. It is worth noting that if the bearing clearance is not stated in the bearing reference it can be assumed to be normal clearance. With a higher clearance there is more tolerance of thermal expansion effects on the rings and rolling elements. When noise and vibration must be restricted, lower clearances are necessary. Ultimately the specific application and operating conditions determine the appropriate internal clearance. For example, paper-drying machines that operate under hot conditions usually need C3 and C4 clearances. The severe vibration in vibrating screens normally means that C3 and C4 clearances are required. Selection of the correct radial internal clearance group is by calculation and you should refer to your bearing manufacturers handbook. If you weren't such a lazy Fecker, you would have googled it like me
Re: Bearing experts
Posted: Tue Nov 24, 2009 7:17 pm
by J1MS
I know from past checks that the Lambretta was originally listed as running on a C3 clearance for both Drive and Mag bearings in the FAG bearing books of old, thats from when Lambrettas were a big enough customer to be listed.
Re: Bearing experts
Posted: Tue Nov 24, 2009 9:53 pm
by corrado
Kinell my brain hurts now.
Re: Bearing experts
Posted: Wed Nov 25, 2009 9:04 am
by oioivespaboy
I'm an electrician and we rebuild the occasional motor at work.
We use C3 bearings in vacuum pump motors because of their high rpm (high rpm for motors that is) and the high internal temps they reach.
I'd suggest that if you had a choice and the C3 bearings aren't too much more than standard, go with the C3.
Re: Bearing experts
Posted: Wed Nov 25, 2009 5:26 pm
by AUSSIE
doesn't the guy with the 100mph lambretta use c4 bearings to reduce friction? im almost certain this was mentioned in the write up about his scooter that was in scootering a while ago
Re: Bearing experts
Posted: Wed Nov 25, 2009 9:49 pm
by oldbiker
C1, C2, C3, etc
C1=Standard tollerance on the rolllers or balls Etc Pluss 1 micron additional clearance
C2=Pluss 2 microns
C3=Pluss 3 microns
Etc. Etc
That`s what the bloke from Fag bearings told me
Use C1 in normal room temperatures and C3 when the bearing is going to run in a hot environment
