Page 1 of 2
Copper Sandwich Exhaust Gaskets
Posted: Fri Nov 20, 2009 5:23 pm
by soulsurfer
Rumaging through my bits and pieces I came across a couple of copper sandwich type TS1 exhaust gaskets, are these worth using or should I cast them aside?
Re: Copper Sandwich Exhaust Gaskets
Posted: Fri Nov 20, 2009 8:11 pm
by corrado
I'd use them but I wouldn't 're-use' them.
Posted: Sat Nov 21, 2009 5:23 pm
by leigh
these are the only ones i personally like, and agree would only use once
Leigh
Posted: Sat Nov 21, 2009 5:49 pm
by YAMLAM
does any body do a solid copper one,i still use( for standard exhaust ) one i got from webbo (MSC ) back in the 80`s,just heat it up with a blowtorch untill it`s cherry red then dunk it in water.
Posted: Sat Nov 21, 2009 6:23 pm
by goldeneye
soulsurfer wrote:Rumaging through my bits and pieces I came across a couple of copper sandwich type TS1 exhaust gaskets, are these worth using or should I cast them aside?
use gilera runner exhaust gaskets, same and cheaper. once you mention TS1 on the fone , the till starts ringing faster at most dealers.
Posted: Sun Nov 22, 2009 3:37 am
by corrado
goldeneye wrote: use gilera runner exhaust gaskets, same and cheaper. once you mention TS1 on the fone , the till starts ringing faster at most dealers.
TS1 gaskets are about £1.40, just googled Gilera runner exhaust gaskets, 1st two I looked at were £3.39 and £1.96, so I'll agree to disagree with you.
Posted: Sun Nov 22, 2009 11:56 am
by goldeneye
your not a dealer are you by any chance...............
Posted: Sun Nov 22, 2009 12:55 pm
by corrado
Yes, so point me in the direction of the 50p Gilera gaskets.
Posted: Sun Nov 22, 2009 3:23 pm
by goldeneye
back of the net! is that a bite?
Posted: Sun Nov 22, 2009 7:18 pm
by Booby
Could be a bit rough on the old teeth
