Page 1 of 2
Big Carb
Posted: Thu Nov 19, 2009 6:45 pm
by woody
Hi, i,m running a sx200 midly tuned with a 42mm ralph saxelby exhaust and want to upgrade from a standard carb ( 22mm) to a larger one . I still want to use the standard air filter and box for the original look , does anybody have any ideas what set up i could use ie what carb ( 26,28,30mm)what manifold etc to get the correct angle and distanst but to upgrade the power . The scooter used to run a 22mm bored out to 26mm and did run much better but the threads on this carb knackered and i had to use a 22mm jetex as i couldn,t get another dellorto so this is out of the question , any suggestions greatfully received ,thanks.
Re: Big Carb
Posted: Thu Nov 19, 2009 6:58 pm
by rog60
Hi, I've used a Jetex bored out to 25.4mm (1inch) to great effect on a 225 cast iron barrel and on my Casa 210 kit. If you want to retain the filter box, you can only go up to about Dellorto PHBL 25/26mm carbs or equivalent.
Bigger carbs are not compatible with using an airbox and filter, a remote filter is normally used. I believe that anything bigger then 28mm carb is overkill...............others may differ, but hey more opinions = more options.
Re: Big Carb
Posted: Fri Nov 20, 2009 9:00 am
by Special X
PHBH26, easy to dial in and you can use the airbox (with the restrictor tube removed)
Re: Big Carb
Posted: Sun Nov 22, 2009 12:43 pm
by woody
Special X wrote:PHBH26, easy to dial in and you can use the airbox (with the restrictor tube removed)
What do you mean by " dial in " and also what manifold do you use with this as one of friends tried this and the one he used left the carb at the wrong angle to use the original filter .
Re: Big Carb
Posted: Sun Nov 22, 2009 1:48 pm
by ArmandTanzarian
Mikuni TM24
Re: Big Carb
Posted: Mon Nov 23, 2009 12:14 am
by rog60
woody wrote:Special X wrote:PHBH26, easy to dial in and you can use the airbox (with the restrictor tube removed)
'Dialled in' is just a term to mean that the carb is jetted correctly for the engine it's being used with.............
Not that I've checked, but if you chat to any of the 'big' names in Lambretta, they will be happy to point you in the right direction for a suitable inlet manifold OR buy a complete kit, carb, manifold, choke and throttle cables, rubber etc. The carb will be jetted to your engine by the supplier AND if any problems he will be happy to advise you on solutions.........simples
Re: Big Carb
Posted: Mon Nov 23, 2009 9:14 am
by cezeta
ArmandTanzarian wrote:Mikuni TM24
without a doubt......welcome to the 21st century
works through the airbox, is descreat, nice operation and makes the motor run clean and crisp.
Re: Big Carb
Posted: Mon Nov 23, 2009 8:45 pm
by rog60
cezeta wrote:ArmandTanzarian wrote:Mikuni TM24
So get one in a kit..............
Re: Big Carb
Posted: Mon Nov 23, 2009 11:05 pm
by cezeta
rog60 wrote:cezeta wrote:ArmandTanzarian wrote:Mikuni TM24
i have, muggy 225, tm24 now running a breath sweet air filter on a machined nylon bell mouth and b race pipe on my jet 200
....now you have a try
Re: Big Carb
Posted: Mon Nov 23, 2009 11:38 pm
by rog60
