indian gp 200 gearbox- ts1 225
Posted: Tue Nov 17, 2009 9:03 pm
by db67
hi, currently running a ts1 225 with a indian gp 200 gearbox & 19x46 sprockets. carb is a 35mm mikuni & exhaust is a jl 3.my question is that i sometimes find that it doesn't pull all that well in 4th so was considering putting the gearbox back to a standard setup ie 18x47 sprockets to see if it would improve. just wanted to know if i did this would make it to 'revvy' as i would much prefer more of a cruising setup. thanks for any info. db :D
Re: indian gp 200 gearbox- ts1 225
Posted: Tue Nov 17, 2009 9:17 pm
by red
You've got the same set up as me apart from I've got a Devtour and I'm happy with it,even though I sometimes need to rag it in 3rd depending on if I'm into a headwind or on an incline.
Not sure whether it would be too revvy or not if you changed the set up though
Posted: Tue Nov 17, 2009 9:18 pm
by chris2470
Hi
Check out the new gearbox visualizer, it should help.
http://scooterotica.org/tempforum/viewt ... f=7&t=6286
