indian gp 200 gearbox- ts1 225
db67
hi, currently running a ts1 225 with a indian gp 200 gearbox & 19x46 sprockets. carb is a 35mm mikuni & exhaust is a jl 3.my question is that i sometimes find that it doesn't pull all that well in 4th so was considering putting the gearbox back to a standard setup ie 18x47 sprockets to see if it would improve. just wanted to know if i did this would make it to 'revvy' as i would much prefer more of a cruising setup. thanks for any info. db :D
red
You've got the same set up as me apart from I've got a Devtour and I'm happy with it,even though I sometimes need to rag it in 3rd depending on if I'm into a headwind or on an incline.
Not sure whether it would be too revvy or not if you changed the set up though
chris2470
Hi
Check out the new gearbox visualizer, it should help.
http://scooterotica.org/tempforum/viewt ... f=7&t=6286
Best Regards
Chris
    Users browsing this forum: Google [Bot], Semrush [Bot] and 5 guests
