Aluminium welding service. CALL-OUT YORKSHIRE AREA OR POSTAL
Posted: Mon Nov 16, 2009 1:14 pm
I am offering my service for welding aluminium, stainless steel and mild steel, via AC/DC TIG for barrels, casings, exhausts and bodywork.
So if you want a barrel repaired or building up around the transfers or exhaust for extra porting scope, alternativly, if you want a case repaired or built up to match a tuned barrel on the gasket face. Or if your stainless steel exhaust has cracked, then give me a PM.
I can come out to you, as my Tig set is single phase and portable, or you can post the item.
I am willing to travel throughout the Yorkshire region for a small travelling charge, so if you and some friends have a few bits needed welding, it would make more sense for me to come to you.
As an idea of cost:
To weld/build up the gasket face to a aluminium barrel: £10+postage
To weld/build up the gasket face and transfer sides to a aluminium barrel: £20+postage
Note: I am using a 'proper' 200amp AC/DC TIG set made by Lincoln, not a cheap set from china. The quality and density (lack of holes) of the 'build up' is as good as it gets.
As a contact please phone 07835748491. If I don't pick up straight away, please just leave a text and I will call back ASAP.
I am in the Cleckheaton area, but as I said I will travel within the Yorkshire region. Any further, it would have to be posted to me. Just phone for any questions.
Frank
As an idea of cost:
Frank
