dragster engine
Posted: Thu Nov 12, 2009 6:56 pm
by vesbrettas
hello there just wanted to know if any body can help me. i striped the clutch any variator out of my dragster about a year ago and put all the bits safely on the side then my misus decided to knock everything over. now its been a while and was just checking if there should be a washer between the variator and the water pump pulley on the crank as i cant find any good diagrams about
any help would be much appriciated
cheers Dan
Re: dragster engine
Posted: Wed Nov 18, 2009 9:34 pm
by e type
[quote="vesbrettas"]was just checking if there should be a washer between the variator and the water pump pulley on the crank as i cant find any good diagrams about
no dont think so hope this helps
Re: dragster engine
Posted: Wed Nov 18, 2009 11:44 pm
by RICSPEED
Best asking on
http://www.scooter-scene.co.uk quite a few into dragsters and I'm sure some one could answer this for you
Just click the fourum tab
Re: dragster engine
Posted: Sat Nov 21, 2009 2:41 pm
by C*NTSPEED
vesbrettas wrote:hello there just wanted to know if any body can help me. i striped the clutch any variator out of my dragster about a year ago and put all the bits safely on the side then my misus decided to knock everything over. now its been a while and was just checking if there should be a washer between the variator and the water pump pulley on the crank as i cant find any good diagrams about
cheers Dan
is it a standerd variator if so then no but if polini or malossi they both have a 4mm washer that fits on the crank before the variator backplate
then...
the gap is the flypully half
