Old school Suzuki 205 by Chiselspeed.
LAMBRETTA DYNO GRAPH POSTING AREA
- registered user
- Main scooter: Spanish Eibar TV200
- Contact:
- registered user
- Main scooter: '71 GP125
- Contact:
his is the last in 3 runs/setups that were done with my standard mugello kit, tested with 28 and 26mm dellorto carbs
ended up with the 26mm, PM expansion chamber, open carb, 17 degrees fixed timing.
feels very good on the road but desperate to get it tuned/ported later this year as I need more go
the TQ figure in the text at the bottom must be some sort of glitch LOL
- drunkmunkey6969
- Moderator
- Contact:
Did you try a bigger atomiser? What's the full setup?
- Main scooter: GP 225 Rapido
- Contact:
- Contact:
Major Hassle wrote: ↑Sat Jul 15, 2017 9:55 am 225 TS1 27Bhp 23ft lbs Torque, cyclone 5, tmx 35 mil, franspeed super tourer
- registered user
- Contact:
Monza '240'
Barrel bored to 71mm with an H2 Wiseco piston
Touring tune by Powolotti
TMX30 carb
Short inlet manifold
60/116 crank
Adspeed ADS3 exhaust
16/46 with an Indian GP200 gearbox
LTH 7-plate clutch with uprated springs
TMX30 carb
60/116 crank
- Attachments
- Capture5.JPG (2.51 KiB) Viewed 13000 times
- Capture.JPG (8.18 KiB) Viewed 13000 times
- drunkmunkey6969
- Moderator
- Contact:
I can’t read those graphs, but knowing Powolotti tuned it, I’m expecting a good power output. What’s the result?Fruitjuice wrote:Monza '240'
TMX30 carb
60/116 crank
- registered user
- Contact:
29.5hp @ 6300rpm
33.7Nm @ 5900rpm
above 20hp from 5200 rpm up to 7500 rpm
above 20Nm from 4800 rpm up to 7400 rpm
33.7Nm @ 5900rpm
