Page 1 of 2
LIGHTER CLUTCH FEEL NEEDED
Posted: Sun Nov 08, 2009 11:10 am
by lambro63
can anyone point me in the right direction, my wifes li 200cc set up is causing her problems as the clutch is far to hard for her to pull in with her hands & grip only being small
so any ideas on how to lighten this up so she can operate it without all the moaning it hurts her hand & fingers
thanku
Re: LIGHTER CLUTCH FEEL NEEDED
Posted: Sun Nov 08, 2009 11:22 am
by soulsurfer
Is it a standard 200 engine Pete? If so, I'd get hold of some NOS Innocenti clutch springs from Scooter Restorations. This way you know what you're getting i.e. the correct tension and size springs for a standard clutch. Otherwise you're at the mercy of springs with no quality control and ultimately too stiff.
Posted: Sun Nov 08, 2009 11:46 am
by ArKaTxU
You can use too this "easy clutch":
Posted: Sun Nov 08, 2009 11:54 am
by soulsurfer
I know of plenty of people that have an Easyclutch in their garage, but none with one fitted to a Lambretta :? Has anyone successfully used one?
Posted: Sun Nov 08, 2009 11:59 am
by ArKaTxU
soulsurfer wrote:I know of plenty of people that have an Easyclutch in their garage, but none with one fitted to a Lambretta :? Has anyone successfully used one?
Yes, i want to know the same :D
Posted: Sun Nov 08, 2009 12:35 pm
by mark
use one on a vespa but never needed it on a bretta . worked fantastically
Posted: Sun Nov 08, 2009 1:24 pm
by eibargum
A dog leg clutch lever aint a bad idea, you can buy them from motor bike shops for as little as £8 and they need very little fettleing to fit a lammy ;) .
Posted: Sun Nov 08, 2009 1:39 pm
by lambro63
thanku soulsurfer & members for your ideas will take a ride to see paul in bullwell for the spings you mentioned
Posted: Sun Nov 08, 2009 7:28 pm
by goldeneye
nylon lined cable?
Posted: Mon Nov 09, 2009 10:15 am
by Killkenny
Why not just fit a MBD clutch lever with a correctly fitted MBD nylon
lined clutch cable, you can pull the clutch in with one
finger........... simple, I dont understand why this is ever an issue!
