Page 1 of 2
Rubbers grommets/lugs...?
Posted: Fri Nov 06, 2009 11:10 am
by sydduckett
Im drilling my frame whilst its apart to run the cables/loom through. The holes will be a combination of round ones (10mm) and elongated ones (10mm wide & 15-20mm long). Does anyone know where i can get rubber grommets (correct word?) that will sit in the holes both round and elongated.
Ideally wanted to locate these before drilling to make sure i drill the diamiter to fit the rubber correctly.
Any advice on this undertaking greatly appreciated.
Sef
Re: Rubbers grommets/lugs...?
Posted: Fri Nov 06, 2009 11:49 am
by RobD
Posted: Fri Nov 06, 2009 2:27 pm
by Angry Bloke
http://www.alexander-industrial.co.uk/
Try these guys, they give out free samples
Posted: Fri Nov 06, 2009 9:28 pm
by Knowledge
I needed a thin, elongated rubber for my legshields so I could feed a cable, and found the one I wanted in a metal wall box from a domestic 13A power socket. I found it in my electrics box in the shed, but if I had had to buy it, it would have been worth the 99p from B&Q for the right size of rubber.
Whenever I find a grommit, I never throw it away.
Posted: Fri Nov 06, 2009 10:37 pm
by sydduckett
Nice one boys, does anyone know the thickness of the loop tube? Didnt realise id need this until i saw the website. Seems as they come in 1.5 & 2.0mm...
Ta
Sef
Posted: Fri Nov 06, 2009 10:42 pm
by cezeta
the trouble with gromets is that they are designed for sheet metal so are dificult to get to fit into the scaffold pole of a lammy as the groove is too small
me and a mate tried and failed on a cutdown so just rounded the edges smooth and painted it
Posted: Fri Nov 06, 2009 10:48 pm
by sean brady scooters
tube thicknesses can vary if you like depending on the thickness of paint/powder coating on them.......
but 2.5/3mm would be more like it.........
Posted: Fri Nov 06, 2009 10:53 pm
by cezeta
sidbucket, i have zillians of 20mm 25mm 32mm......if you need a few. literaly they are all over the floor of my van
by Dazza
As a sparky by trade and know about grommets etc - I'd reccomend grommet strip, it's a nylon material rather than rubber and is almost translucent.
You cut it to length and fit it into the hole just like a conventional grommet- the trick to stop it falling out is to set fire to a peice and wait for it to start melting then 'weld ' the piece youve fitted with molten plastic.
If you go into an electrical wholesalers they may give you a sample - they come in various thicknesses too.
Posted: Sat Nov 07, 2009 12:33 am
by sydduckett
Cez, cheers for the offer, may well take you up on it. Went to the 2nd link supplied on this thread and you can indeed order free samples so have ordered 20...
Ill see if they actually turn up first, knowing my luck and the post office its unlikley...
Still havent been able to find one for a slot as opposed to a hole....
Sef
