new fast flows
Posted: Mon Nov 02, 2009 8:36 pm
by pasner
Could someone tell me wich fastflows are using the guys of dactec in their engines? concrete model, where to buy it.
I dont really like the ones you can find on scooter centre, not easy to fit. thanks.
Re: new fast flows
Posted: Mon Nov 02, 2009 8:39 pm
by mark
im using a taffspeed one on my dac , but they run a pumper carb so that sucks as much fuel as it needs
Re: new fast flows
Posted: Mon Nov 02, 2009 8:47 pm
by pasner
My Scooter Centre fastflow chafes with the engine mounts, not talking about the flow, I want something that fits like a standard one.
Re: new fast flows
Posted: Mon Nov 02, 2009 8:49 pm
by mark
loosen tank straps and twist tank. the dac tanks are mounted at front of engine bay so run the fuel tap in front of engine mounts
Re: new fast flows
Posted: Mon Nov 02, 2009 8:54 pm
by pasner
I will try, but Im thinking in an open/close tap from another motorbike or something similar. Any ideas out ther?
Re: new fast flows
Posted: Tue Nov 03, 2009 1:47 am
by corrado
Have you seen the Cambridge Lambretta ones? The outlet goes sideways instead of straight down so there should be less chance of it fouling on the engine mount.
Re: new fast flows
Posted: Tue Nov 03, 2009 2:17 am
by MarkH
Any motorcycle fuel tap is going to have a lever right on the tap itself. If you run without panels this is an option for you, or a good inline tap. Lambretta taps are somewhat unique with the long lever I think.
OMG are the ones making the different fuel taps out there. The straight, the 90 degree, and the ones with the warning light are available to any reseller.
Re: new fast flows
Posted: Wed Nov 04, 2009 6:34 pm
by DaveInPortland
MarkH wrote:Any motorcycle fuel tap is going to have a lever right on the tap itself. If you run without panels this is an option for you, or a good inline tap. Lambretta taps are somewhat unique with the long lever I think.
Bring some 90-degree versions to the States, please!
Re: new fast flows
Posted: Wed Nov 04, 2009 6:40 pm
by MarkH
already en route :bouncing:
