What cc ???
Posted: Fri Oct 30, 2009 4:56 pm
by Train Driver
62mm crank with a 115 rod using a 71 mm piston what will be the cc,
I am still not sure if i shoud go with a Mb RT kit or stay with my classic rapido 225.
I will be getting the crank whatever
Re: What cc ???
Posted: Fri Oct 30, 2009 5:13 pm
by Stokie
If you're considering the RT because of the tuning then why not send your Rapido to MB (or someone else) to have it tuned to a similar spec ?
I'd have thought it'd be the less costly option.
Re: What cc ???
Posted: Fri Oct 30, 2009 9:48 pm
by Train Driver
Well happy with the rapido so will most likely stay with it, the engine is going up to chalky at replay who has a 63mm crank
it was chalky who tried to explain about con rod length (115/116 better)
Staying with the 24mm mikuni and ancillotti clubman
