carbon fibre clutch plates and steels
Posted: Fri Oct 30, 2009 10:38 am
by druist
I picked up off a well know online auctioneers, what was supposed to be Taffspeed 5 plate clutch, i got 4 steels and 5 plates which look like carbon fibre, green colour with surflex stamped on, nothing like ordinary cork ones and the springs. a) does this sound complete? I thought a top plate should be there, and wondered slightly as they had minor surface rust. The seller said they were bought for a project but not used, they were cheap enough so i thought i best get em. Got a basket which certainly looks higher but again how can i tell if this is ok?
Also, if i was to use these as I am in need of a 5 plate due to an imola being used in the engine build, what else do i need, eg crown wheel?? Will my gp top plate suffice?
thanks guys
Re: carbon fibre clutch plates and steels
Posted: Fri Oct 30, 2009 3:17 pm
by corrado
Sounds like they're the "Green" racing corks not carbon. The steels will go rusty if not coated with oil, it's not a problem and the idea is that you reuse your own top plate hence 5 corks and 4 steels. The corks and steels are thinner so should fit in a std set up.
