Rapido race with ancillotti exhaust 30mm carb, set up needed
Posted: Wed Oct 28, 2009 7:00 pm
by dodobeckam
hi advice needed..using rappido 225 race ancillotti exhaust with a 30mm dellorto carb set up needed.thanks in advance.....mike
Re: Rapido race with ancillotti exhaust 30mm carb, set up needed
Posted: Mon Nov 30, 2009 10:44 pm
by paddyfitz
I set up one of those w/ a round slide (phb)30mm, the clubman I used was a 48mil AF.
I had pretty good success w/ the following:
266 tube, X4 needle on the 3rd clip, 55 idle jet, 128 main was kinda lean, 132 started to rich out, settled in the middle. Air filter configuration will be a factor. I found that flat out, the float would drain faster than I wanted, so I put a 300mm float needle aperture in it instead of the 200mm it came with.
Every bike is different. :)
Good luck.
