26 jetex
Posted: Sun Oct 25, 2009 3:45 pm
by panamesc
to save the original look of my 69 jet 225 , where can i find a decent 26 jetex ???
af ???
thank you !!!
Re: 26 jetex
Posted: Sun Oct 25, 2009 8:22 pm
by rog60
AF also sell a reamed out to 26mm, 22mm inlet manifold and carb or get an engineer to ream out the body for you. 26mm is a bit too wide as the air can bypass the slide (slight gap),I have one of each btw, I suggest to 1" (25.4mm).......................
Re: 26 jetex
Posted: Sun Oct 25, 2009 9:57 pm
by panamesc
thank you
will buy a 22 carb & manifold and ask to a friend for 1"
if he can't or don't want i use the AF way ;)
Re: 26 jetex
Posted: Mon Oct 26, 2009 12:08 am
by rog60
BTW. Using a reamed out carb/manifold on my 200 stage 4 did make a slight difference to acceleration and the engine seemed to rev on a little more.........................
Re: 26 jetex
Posted: Wed Oct 28, 2009 7:57 am
by Special X
Arthur Francis used to ream the 22 Delly to 24mm . . . they worked fine. 26mm is too big go to 24mm.
Re: 26 jetex
Posted: Thu Oct 29, 2009 1:30 am
by rog60
Special X wrote:Arthur Francis used to ream the 22 Delly to 24mm . . . they worked fine. 26mm is too big go to 24mm.
Any particular thinking for this answer? as mine went very well and was economical on fuel :?: :?:
