62mm Crank
Dimitrios_231
Does MBD do a 62mm Race-Tour crankshaft?
I want to build a real 250cc engine.
Train Driver
Yes Mb do a 62mm and 64mm crank but mark likes to build the engines with these cranks. Chalkie at replay scooters and Jb also do this size crank. Reading about cranks on this and other forums 62mm with a 115 rod seems the best combination, unless Cezeta thinks otherwise :ugeek:
Dimitrios_231
I can't see them, at their online site :?:
Train Driver
Dimitrios_231
Thank you for the links
(Very late response :D )
Knowledge
I believe that JB's longest stroke is 63mm stroke, as he has not found a 64mm crank that ticks all his boxes.
Martin
