Getting powder coat off
Posted: Sat Oct 24, 2009 6:45 pm
by essexgp
Am in the process of building my second project, an indian gp cutdown, frames cut and am now in the process of trying to remove the powder coat that someones put on it (only want it off the frame loop really).
My question is whats the best way to get it off as its hard work with a wire brush attachment in a drill and its a bit over the top with an angle grinder, so whats the best way?
Re: Getting powder coat off
Posted: Sat Oct 24, 2009 6:57 pm
by leehuggy72
i had my parts bead blasted
Posted: Sat Oct 24, 2009 7:13 pm
by bristolmod
leehuggy72 wrote:i had my parts bead blasted
Christ..........I bet that hurt
Posted: Sat Oct 24, 2009 7:27 pm
by rog60
Nitromoors...............
Posted: Sat Oct 24, 2009 7:43 pm
by Andy Pickering
bristolmod wrote:leehuggy72 wrote:i had my parts bead blasted
PMSL..Back to post, why do you want to remove it matey, you can use the powder coat as an excellent base for primer..just flat it off and prime, less chance of rust coming through at a later date..
Posted: Sat Oct 24, 2009 7:47 pm
by fred
take it to a powder coaters to be chemically stripped,doesn't take long at all. And shouldn't cost much.
Posted: Sat Oct 24, 2009 7:49 pm
by C*NTSPEED
nitromors does it for me also
Posted: Sat Oct 24, 2009 8:37 pm
by rog60
Lam46 wrote:bristolmod wrote:leehuggy72 wrote:i had my parts bead blasted
I agree, had a few things sprayed over powder coat.............
Posted: Sat Oct 24, 2009 9:11 pm
by essexgp
Im only stripping the frame hoop as im welding up the tool box door, air intake, choke and lever holes. The frame itself I will flat and use the powder coat as a base.
Thanks for the answers anyway, will try nitromors next then
