halogen and led rear
Posted: Tue Oct 20, 2009 11:01 pm
by leehuggy72
sorry to cover old ground,
i'm i right to use a osram nightbreaker 60/55w xenon h4 bulb for the front....
and this
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
for the rear..
can you get led festoons for the rear aswell..
any advice would be great
Re: halogen and led rear
Posted: Wed Oct 21, 2009 6:27 pm
by leehuggy72
that'll be a NO then :shock:
Posted: Wed Oct 21, 2009 6:56 pm
by soulsurfer
leehuggy72 wrote:that'll be a NO then :shock:
Yes, I mean no, I mean yes, that led rear bulb is ok just check the length will fit with your reflector fitted. The H4 Nightbreaker is fine with the rear led as long as you've made the necessary alterations to your bulb holder and aren't powering much else in accessories. LED festoons are available here amongst others
Posted: Wed Oct 21, 2009 7:19 pm
by leehuggy72
Thanks mate ;)
Posted: Wed Oct 21, 2009 10:53 pm
by rog60
Yes and no. I've fitted a similar led bulb from Sparkright Technologies, been on two years no probs and had that fitted with an H4 55/60 watt bulb again no probs to a previous scoot with Indian Electronics. Am currently in prosess of fitting H4 bulb to current machine (GP200) with standard electronics
Any use :?: :?: :?: .
Posted: Wed Oct 21, 2009 10:58 pm
by corrado
Had lots of bulb blowing front and rear on my GP until I fitted the sparkrite set up and got my own LED for the rear. Never had a problem since. My rear led is one that the filaments face one way so don't illuminate the number plate but as it's never failed an mot like that I see it as a plus point.
Posted: Thu Oct 22, 2009 12:08 am
by rog60
corrado wrote:Had lots of bulb blowing front and rear on my GP until I fitted the sparkrite set up and got my own LED for the rear. Never had a problem since. My rear led is one that the filaments face one way so don't illuminate the number plate but as it's never failed an mot like that I see it as a plus point.
As you know Gp rear lenses don't have the clear plastic insert to illuminate the rear number plate so same here, but as I had it and it does make the rear lense brighter, I thought......might as well use it.
