rear hub studs
joda
just got a ok rear hub, but the studds are no good, they have a hex head on the back, so do they unscrew or are they pressed? is it a normal thread or a left hand thread?
where is the best place to get new studs, cone etc??
ta
leehuggy72
http://www.scooterrestorations.com/lambretta/hub-stud/
left hand thread as far as i know........
Knowledge
Jed,
I have seen both press-in and LH thread studs with hex heads, so it is not always obvious. Some of the screw-in items have a very slightly domes appearance, but others are flat.
The best press-in replacements are made by MB. Not cheap, but far better than others that I have seen, bought and then rejected on safety grounds.
Martin
rog60
Main scooter: Indian GP200
Knowledge wrote:Jed,
Ones I bought from Scooter Resorations were flat thin hex headed LEFT hand threads. Suggest you try to unscrew them (they should be very tight) and see what happens................
    Users browsing this forum: Google [Bot], Semrush [Bot] and 11 guests
