tm 24 set up
acab
Main scooter: gp 200
alright,setting up my carb and it seems to start better from cold with throttle 1/4 open,would this indicate pilot to small?set up is
sill 200
mikuni tm24
pilot 15,leaner needle 4d thingy 2nd clip,185 main
42mil clubby
anybody running same as everyone seems to use the richer needle
Robi D
any luck with this? i'm running similar set up with a scootrs pipe. seems to always want to run better with the throttle opened a bit. never idles really well.
acab
Hi pal,not had the chance to change anything yet but was out yesterday and after 30 miles decided to pull over and check plug and discovered it running lean,gonna change to richer needle,seemed to be going well.Do you use the leaner needle?thought i d bossed it but never mind and what sort of miles are you getting pal?.
thank for your help.
Pat.
Robi D
Hi Pat,
Well i use a stock 5N14 needle but also have the 4DH7 as suggested by many others using the same kit as me. It is a leaner needle but i didn't find that it ran very well with it in. So i stuck with the stock needle. Not sure of the milage yet, I really don't have more then 400 miles on it since the build of my engine. I had a 28 mikuni on for the first 250 to 300 miles, and i switched it out because i was using what i thought was alot of gas, but it is really no different then the 24!! I use a half tank going to my girlfriends house which is about 35 miles away. On my stock ser. 2 li 150 i would use maybe 1/4 tank!! and i mean maybe, doing the same trip.
I have also found my idle screw is turned all the way in and back maybe one full turn for it to idle right, i also find that in order for it to keep running when cold i need to keep it at 1/8 to 1/4 throttle or it will quit. But it's fine after it's warmed up.
Don't know if any of that is a help to you. I'm running in the third clip down, and i hate to say i don't remember, but i think a 165 main, 15 pilot. This is on a 150 that has been converted to a 190.
Cheers
    Users browsing this forum: Ahrefs [Bot] and 1 guest
