Water Temp
mine ticking over takes about 5 mins but about 2 mins if im riding. this all depends on where you temp sensor is situated and if you using a thermostat and water pump. i cant remember what my thermostat opens at sadly ,hot water is then pumped around to rads when it opens(pump runs all the time)going past my sensor and fan switch which are in the pipe from pump to rad. on the motorway in belgium it was reading 57-62 c, around town it was reading between 75-85 c. i am now moving my sensor into the head to get a truer reading of running temp and putting fan switch into rad mainly to tidy things up
Wayne Miller
- registered user
- Main scooter: Vespa 50 Special (Rotax Proto)
- Contact:
It depends on wether your using an addittional head gasket and increasing your squish or notBilko wrote:For running normal round town. How long would it take to get the water temperature up over 40 degrees C?
Hope all goes well for you mate
Stay tuned..............
Wayne Miller
- registered user
- Contact:
What are you using? mine doesnt start to register until the temos above 30 c.Bilko wrote:Thanks Mark
LOL! Thanks Wayne.
Now I know my water temp gauge isn't working.
Mines Vapourtech Stealth or at least I think thats what its called
Mine starts to register after about 2/3 mins at tick over
Bilko
- registered user
- Main scooter: LI150
- Contact:
TIm Temperature gauge.
I think it could be the sender. It's a Koso one, but the connector was unique so I took it to an electrical shop where they put connectors on the wires.
I dunno.
I might try and see if I can find another sender, but I don't know what the tapered thread size is on the connector.
AAAaaaaarrrrgggghhhhhhh!
I'm off to bed before I get another headache!
I dunno.
